D500 intake manifold - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-28-2008, 11:11 AM
hi, my name is steve and im new in this forum. i drive a ´57dodge custom royal lancer with a 5.3 l 325cui engine with a 2 bbl carb.
is it possible to use the ´57 intake manifold for a 4bbl.single carb. from the D500?
if it works, where can i get one?
thanks, steve
Old 09-28-2008, 12:26 PM
Originally Posted by Lude74
hi, my name is steve and im new in this forum. i drive a ?57dodge custom royal lancer with a 5.3 l 325cui engine with a 2 bbl carb.
is it possible to use the ?57 intake manifold for a 4bbl.single carb. from the D500?
thanks, steve
Yes within the nameplate many if not all Hemi parts swap. This is not true across brands, Chrysler, DeSoto, Dodge, Plymouth hemis are unique with a couple parts that interchange here and there, intakes not among them.
check this out for some help:
http://hotrodsandhemis.com/
Bogie
Old 09-28-2008, 04:33 PM
OHD's Avatar
OHD OHD is offline
4 bbl manifolds for Dodge
casting number 1537723 55 year
1634262 56 year
1735774 57 year
one posts the casting numbers for the manifolds then gets the post below...
Old 09-30-2008, 11:30 AM
hi, on my intake manfold i found the following nr.
1735774-2
who can help with a 1x4bbl intake manifold?
thanks, steve
Old 09-30-2008, 02:37 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
If it is of any interest to you, Exeter Auto Supply shows to have one Offenhauser #3615 3x2-bbl aluminum intake manifold in stock. These were made with either 3-bolt or 4-bolt carb bases, so you should contact them to find out which it is. The price is US$ 353.99. Offenhauser also made a model# 3614 which mounts 2x4-bbl carbs, probably the Carter WCFB small 4-bbl carbs (I would guess they would flow 350-400 CFM each).
http://www.exeterautosupply.com/Contact.html
Performance Automotive Warehouse shows a listing of both manifolds. #OFF-3614 2x4 for US$299.95 and #OFF-3615-4B for the 4-bolt 3x2 manifold US$353.95
https://secure.pawengineparts.com/sh...art/index.html
You can find the WCFB carbs on ebay.....
http://motors.shop.ebay.com/items/WC...BQQ_trksidZm39
As far as carbs for the 3x2, they would be Rochester small-base carbs having 1 7/16" throttle blades. The flange bolts are centered on a 3 1/4" X 2 7/8" rectangle. You might find them on ebay or you could run a "wanted" ad in Hemmings Motor News. The small base come with a side inlet or front inlet and flow 280 CFM. All side inlets were small base no side inlets were made in large base. Have the supplier to measure the carb base size on the 3x2 manifold to be sure.
Altima GXE Intake Manifold Gasket awbazar Engine 5 01-24-2010 07:45 AM
intake manifold is messed up, need help picking another 84Z Engine 1 08-21-2007 04:57 AM
Intake manifold volume techinspector1 Engine 8 07-13-2007 10:43 PM
Building A 302 Chevy Scorpio Shaping Flow Hotrodding Basics 6 01-16-2007 05:55 AM
Intake Manifold Bolts - Need Sleeves?? jerseyjeff Engine 5 11-18-2003 01:00 PM
