DA-Dual Action only?
I just got a National Detroit DA, it's a great tool that uses a lot less
air than my cheap one, but, I thought I would be able to lock the shaft and use it as a rotary, but no, the lock is only for pad removal. The tool says there's a loss of power if the shaft lock is on and you really can't use it that way. I'm really disappointed. I thought I read on here about using DA's in the rotary position, is this a feature only found on those super pricey units?
Update.
Well I couldn't find a DA that was capable of rotary only mode so I exchanged mine for a National Detroit rotary sander. It's just like a DA except it spins only, without the dual action. This thing strips paint unbelievably fast. I love it.
Most of the time when I use my DA in the rotary mode (which isn't often) it just abrades on one side of the disc anyway.
Or the disc adhesive lets go and the paper becomes a frisbee. I usually only locked the disc when I used a DA for grinding tool marks off of an aluminum part so I can polish it. I have since adapted a PSA style backing pad to my 5" air disc grinder. That way I can use the finer grit PSA type discs in a rotary fashion. I just made an adapter with the 1/2-20 threads on one side and the 5/16 24 threads on the other. Later, mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example |
| Recent Garage - Tools posts with photos |
| Dual action v.s random orbit? | Gearhead forever | Garage - Tools | 5 | 07-20-2005 01:11 AM |
| DA sanding vs hand sanding | Kevin45 | Body - Exterior | 31 | 07-19-2005 01:37 PM |
| Dual Action Sanders | Dubz | Body - Exterior | 16 | 02-23-2004 08:32 AM |
| Dual Quad setup | chevyIIdie4 | Engine | 8 | 06-23-2003 09:31 AM |
| Single plane and duel plane manifold | stonedchihuahua | Engine | 21 | 01-06-2003 11:56 PM |
