Is it a DA or Random Orbit or???? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-06-2006, 06:06 AM
I have a Craftsmen DA sander. Orbit Diameter is 3/16 and max speed 10,000 rpms. Is this the same as a random orbit sander? Can I use this with Abralon pads?
Or is this not the type of sander to use. It is the one with a handle on it. Not a palm sander. I used it in past to level body filler.
I do have a Hutchins nib/spot random orbit sander but it is only a 3".
I would hate to buy another sander for $200.
Just need to know if i can use this one.
Old 10-06-2006, 08:07 AM
It sounds like your Craftsmen sander is a "DA" and not very good for finishing or fine work. Does it have a lock right above the sanding pad that will prevent it from orbiting and act as a grinder with the disc only spinning?
Old 10-06-2006, 08:10 AM
yes it does have that lock. is that good or bad?
Old 10-06-2006, 08:52 AM
STUPID is as STUPID does...
D/A stands for "Dual Action" the locking feature lets your D/A work as a random orbit sander when unlocked or a grinder/sander when locked.
I would think it would work just fine for finish work when unlocked. I use mine with a 3M soft pad all the time with good results.
Mark
Old 10-06-2006, 08:55 AM
good enough
Old 10-06-2006, 09:01 AM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
That lock is what makes it random orbit or "spin only"
Some DA's don't have that choice so your's is both.
Old 10-06-2006, 10:11 AM
adtkart@aol.com
That kind can be used for that, however they are harder to control. The palm type are easier to use and most have smaller orbits. If you are going to use it to make a living, I would strongly suggest buying a name brand like Dynabrade or Hutchens. If it is something that you only need for this job and are not planning on using often, they can be bought at alot of places for alot less money.
Aaron
Old 10-06-2006, 12:01 PM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
Most air DA's pads are removable with the wrench for it. Just screws on with a right hand thread (normal) stud or the with locking type,just lock it and twist, and you can use a 3",5",6" pad for PSA or Velcro back paper as well. I swap mine out all the time depending on paper or procedure.
Getting started with DA sanding Josh C Body - Exterior 21 06-09-2006 02:06 PM
DA scratches when color sanding MrsBondoQueen Body - Exterior 31 10-26-2005 06:41 PM
Dual action v.s random orbit? Gearhead forever Garage - Tools 5 07-20-2005 01:11 AM
DA sanding vs hand sanding Kevin45 Body - Exterior 31 07-19-2005 01:37 PM
Source of wet-or-dry for DA sander? willys36@aol.com Body - Exterior 3 12-15-2004 06:08 PM
