DA scratches when color sanding - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 10-26-2005, 06:35 PM
Osh Osh is offline
New Member
I've been watching this thread for a few days and am surprised nobody mentioned the difference in d/a's themselves. I use to use a National Detroit d/a years ago to cut down mud and to feather edge. That tool imho is way to aggressive for this sort of thing. Now I use a Hutchin's for this and a Dynabrade for dry and wetsanding the paint. Usually start with 1200 dry then 1500 wet with a interface pad followed with 3000 trizact wet. A couple of swipes with perfect-it 2 and it's done. The smoother the tool the better the finish. Just my .02
  #32 (permalink)
Old 10-26-2005, 06:41 PM
BondoKing's Avatar
KING OF BONDO
Last journal entry: My little helper
I used a hutchins finish sander for this
Matthew
DA sanding vs hand sanding Kevin45 Body - Exterior 31 07-19-2005 01:37 PM
How can I eliminate sanding scratches jpd37 Body - Exterior 4 06-02-2005 10:35 AM
Can you get out DA scratches from glass? BondoKing Body - Exterior 15 05-06-2005 07:22 PM
DA sander scratches in rear window rusty428cj Body - Exterior 2 02-15-2005 07:13 AM
Will water ruin an air powered DA STATUTORY GRAPE Body - Exterior 9 12-10-2004 05:47 PM
