Dacco transmission parts - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-25-2008, 08:26 PM
hey guys, i was just wanting to get some info about Dacco products, I am looking into getting a stall converter through them 33-3500 stall part # PP3402. Do any of you guy's know if there products are any good? anyone got expirience runnin them? Also it says it's for a TH350 or TH400, is that possible to fit both? i thought they had different shaft's/splines. My motor has is a 355 SBC with a lunati bracket master 2 camshaft 300 adv. dur. with .515/.515 lift on both valves
Old 08-25-2008, 10:07 PM
SSedan64's Avatar
I've used several Dacco TCs with good results. They're cheaply priced too. Yes the TH350 & TH400 use the same TC with exception to the TH350C which uses it's own TC.
Old 08-25-2008, 10:20 PM
stall speed
would that much stall be good for my cam, I also have access to a B&M torkmaster 2500, which would be better.
Old 08-26-2008, 12:07 AM
SSedan64's Avatar
With your 3.08 gears the 33-3500rpm stall will work better. You'll probably only see around 3000 stall anyway.
Parts here parts there parts everywhere charger528 Hotrodders' Lounge 5 09-14-2007 01:38 AM
What Is It With Me And Parts.... BigBlockBabe Off-Topic 5 09-11-2007 11:14 AM
Sanding the *%^$&# primer all off the fiberglass parts Ripped Body - Exterior 7 09-01-2007 07:56 PM
Brake parts cleaner oldred Suspension - Brakes - Steering 5 08-29-2007 03:57 PM
Race Transmission Slipping brainsboy Transmission - Rearend 8 03-05-2005 08:01 PM
