daily driven 3000 stall - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-10-2006, 10:25 AM
firestone's Avatar
http://teamrfc.gospelcom.net
Hi, do you guys know of any downfalls to using a 3000 stall in a daily driven vehicle? Will it build up alot of heat and hurt the tranny or will a good tranny cooler fix that? The feel of it does not matter, I just want to know if it will hurt anything. The car is a 1989 mustang.
Thanks,
Adam
Old 07-10-2006, 11:01 AM
S10xGN's Avatar
Gotta love a turbo!
Is it a lock-up? I drive a 3400 stall 9" converter on the street (L/U) and you don't even know it's there... The TCC (clutch solenoid) went out once and my cruise RPM went from 2200 to 3100. That increase in RPM represents a bunch of internal fluid "thrashing". You shouldn't see any appreciable difference in heat if it's a L/U, but a non-locking converter will make a bunch more heat.
Russ
Old 07-10-2006, 12:49 PM
firestone's Avatar
Thanks, I assume that you have an overdrive transmission right? The car is a friend of mines, so I am not sure if he has overdrive or if he is going to get a lockup converter. Is there any way to have a tranny that you can choose if it locks up or not? If he has a 3 speed, It would be nice to be able to have it lock up on the street but not at the track.
Adam
Old 07-12-2006, 10:19 AM
xntrik's Avatar
Save a horse, Ride a Cowboy.
The lock-up switch on my assembly line stock car and TH-350 went out and I dropped 10% in gas mileage. Probably a 1600 stall.
I would suggest the biggest cooler you can physically fit in there and use a thermostat. See Jegs trans cooler page for thermostat. Synthetic fluid is worth the money.
www.readershotrods.com
non-lock 3000 stall for 700r4 KeithB123 Transmission - Rearend 3 03-18-2004 07:58 PM
jegs 3000 stall jo5hi3 Transmission - Rearend 1 03-01-2004 01:57 PM
Anyone run a mild BB, 3:08 gear, 3000 stall? Frank K Transmission - Rearend 2 01-16-2004 08:42 PM
good cam for a daily driven sbc350 66truck4spd Engine 2 11-22-2003 04:03 AM
3000 stall converter question clarence-nieuwhof Transmission - Rearend 3 06-08-2003 05:55 PM
