hi i'm new to this forum and new to all of this....
i just want some opinion on a truck i want to get
it's a 1985 toyota pickup with a 400 sbc
has a 6 - 10 inch left
engine has
-202 heads port and polished
-larger stronger valve springs
-roller rockers
-5 angle valve job
-edelbrock performace intake
-holley 770cfm truck avenger carb
-extreme energy comp cams unknown size but it's big
heavy duty turbo 350
208 transfer case
hooker headers
38" 15.50 r15 TSL boggers
b&m rachet swifter
4:37 gears with front open and rear end lincoln locker
electric fuel pump
rad is in the box
2" wheel spacers
i live in canada and it's winter for 8 months, i just want to know if this will be okay as a daily driver mostly in winter when it's -30 outside. i have a 500whp subaru sti so i dont really care about fuel mileage
what do you call the beast? a chevota or Toylet?
What part of Canada is winter 8 months? The 400 is a decent engine and if the person that built it used good parts then,drive the wheels off it
I know you did,but I dont know the OP so I should behave.
There seems to be quite a few land cruisers with sbc conversions and a bell housing is available to use the Toyota transmission
If you used a 28" tire and a 3.25 rear gear, you would make the same speed at the same rpm's that you would if you used a 4.37 rear gear and a 38" tire. Now, if your truck did have 28" tires and a 3.25 gear, you certainly wouldn't install a "big" cam and expect it to perform correctly. You would add more gear. Let's say that you changed out the 3.25 cogs for a set of 4.18 cogs in order to "get up on the cam". I'm fully aware that there are no such cogs available for your differentials, I'm just crunchin' numbers for you to show you that you will need more gear with those meats. In order to have the same speed and rpm as you would with 28" tires and a 4.18 gear, you will need a set of 5.71's front and rear. Yes, that is a real gearset for a Toyota differential.
A SBC toyota with 38's wont need 571 gears unless its a "mud only" truck. Also the 529 and 571 gear set's are known for tearing up the gear sets. 488 or 513 ratio should work well.
If you use a toyota transfer case then gears do not matter for off road as you can stack them and low range is 3:1. Just worry about whats good enough on the street
thx for the comments, but yea, too much work and i need a daily driver. Alberta has winter for 8 months. I'm going into field work as a welder and i need a car, so i bought a 1999 subaru impreza 2.5rs coupe with a complete wrx swap for my new dd =D much more reliable
Says lincoln locker, so no I would not drive it on the street.
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
