Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Dakota digital dash problem
Old 09-14-2007, 08:02 AM
1969NovaSS's Avatar
1969NovaSS 1969NovaSS is offline
turbo lag......yeeeeehaaaaaaw
well the speed reads 00 and doesn't flicker. The tach and the bar graph do not either. The volt, oil pres, and water temp are the ones that flicker. This may get tricky because I ran alt. wire down the intake with the water sender then they go separate ways. The oil sender runs with the 12v to e the kick down(th400) right next to the distributor(sbc). The volts are picked up from a switched 12v under the dash. The control box is mounted under the dash, upside down, right above and behind the distributor.Do you see any problems with those routings? Should I tell him to get new wires from autozone? I just don't want to do that and still have the problem. By the way Mikey It was late and spell check didn't pickup on it. When I have the Key On Engine Off it runs fine..
