Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Dakota digital dash problem
Old 09-14-2007, 09:23 AM
powerrodsmike's Avatar
powerrodsmike powerrodsmike is offline
Wiki Edits: 161
Try the plug wires first. I'll bet that's it.
You can see if the alt wire is doing anything by pulling it loose and starting the car, then look for changes in behavior.
Also, try running a continous independent ground wire from the motor to the control box. Just a temporary one will tell you what you need to know.
later, mikey
BE different....ACT normal.
