Damage?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-02-2012, 08:26 PM
Damage??
Before putting my 427 engine in, I wanted to make sure that my timing tape was dead on, so i used a Piston stoper to make sure, well i put my piston stopper a little to far in and i think i hit the valves, the threads on the piston stoper are nicked, i'm worried i might of done damage to one of valves??
Old 07-02-2012, 08:58 PM
68NovaSS's Avatar
Wiki Edits: 9
I doubt you did any damage, is this a hydraulic cam? And you were turning it slowly by hand? I would do a compression check just for peace of mind and pull the valve covers and have a look around.
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you.
Midnight Sun Street Rod Association
Old 07-02-2012, 09:19 PM
The engine was just rebuilt with Edelbrock Aluminum RPM Heads, and the engine has not ran yet, yea i was turning it by hand, i had the valve covers off when doing it, i didn't see anything, what should i look for?
Old 07-02-2012, 09:27 PM
68NovaSS's Avatar
Wiki Edits: 9
The only thing you could possibly see is a valve sticking open, or a bent pushrod. It doesn't look like you hit hard enough for any of that. JMO
Old 07-02-2012, 09:30 PM
Yea good idea, well i thought of buying a inspection camera, i can get one with a 9.5MM camera head, so i will check it out tomorrow
Old 07-02-2012, 10:07 PM
and yes it is a roller cam
Old 07-02-2012, 10:53 PM
F-BIRD'88's Avatar
Yada Yada Yada
Next time loosen off the rockers completely on that cylinder before installing the piston stop.
Yes you may have bent a valve.
Old 07-03-2012, 05:26 AM
damage
do a leak down or comp test.you could put compressed air into that cyl and listen for air leak if you dont have comp tester or leak down gauge
Old 07-03-2012, 07:12 AM
bigblockragtop's Avatar
I did the same exact thing with mine. I never took it apart but it has 10k miles on it since. I was using it to check timing like you(TDC) Then I would just unsecrew it and rescrew it As it go closer after that to check it. I can't say you did not hurt anything but I don't think I did Good luck
motor damage??? whitesephiroth Engine 13 08-26-2009 07:13 PM
how much damage did it cause? chevelle4542speed Engine 8 05-29-2006 07:54 PM
Did I do any damage? Marcus Transmission - Rearend 6 05-25-2005 02:35 AM
The damage Novaman78 Hotrodders' Lounge 10 07-22-2004 07:05 PM
fire damage Stinkin_V8 General Rodding Tech 5 04-15-2003 04:24 PM
