You need the proper guideplates for Merlin heads I believe, I have cut the stock Chevy type at the joining strap and then brazed them back together in position with a short piece of 1/8" mild steel. It doesn't look pretty but it works and gives you the opportunity to align them perfectly. As long as your quick and quench them with a wet rag you won't remove too much of the heat treat.
Outlawed tunes from outlawed pipes |
I have the proper World Guideplates, there the problem?
I like your idea about splitting them in the middle and rewelding them, i have a MIG welder, do you thing i could use it? and would it be strong enough?? Cheers RobbieRat |
Hi All...........
Well i finally managed to sort these bloody guideplates out After much cutting and welding and more recutting and welding i had to find a better wayProblem with all the cutting and welding is they still move into the wrong place when cool.I wasn't game enough to weld right on my brand new heads so i used old ones instead for the welding.Which is a bit hit n miss. Even after torqueing them into place and welding them and then tranfering them to the Merlins, one would always be out a tad So i decided to buy a new set, torque em in place and check tip alignment, interestingly things wern't as bad as with the World guideplates(bonus). Only about half needed adjusting, i also found out guideplates crack real easy the hard way.One major difference in the two brands of guideplates is the hole in the base, World have a huge hole, which tend to move around under tightening which is a prob in itself and the Pioneer i used are very tight on the studs and can't move period. Now all i need to do is realign the misaligned ones, and thats pretty easy if you have an oxy set. I just heated the vertical part of the guideplate redhot and twisted it to suite the rocker tip. The result is perfect rocker tip alignment and now with 1/4'' longer onepiece pushrods the geometry is correct and the whole job only took a few hours so the rest of the afternoon was spent drinking beer and celebrating!
