Damn im dumb need lots of help - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-10-2004, 12:12 AM
Brian Morency's Avatar
Hauling A55 BURNING GASS!!!
Last journal entry: bros car
yea just posted a horsepower question and thanx for the answer but i didnt give correct info. i own a 1988 firebird formula 305 i was told high output with a TBI and i dont know what kind of trans except it is going out soon. i needed to know the horsepower because i was told the car was fast but right now the motor mounts are broken or worn because it jumps when i punch it and when i tried to do a brake touqe today the rpms would not go up much and if i gave it lots of gas it would lose power i have no idea what is wrong and maybe some 1 else knows the answer and could help me out on what to do with this car. i dont like ricers thats why i bought this car and i want to fix it up.it also sat for 2years and i dont know what i should replace to make it run better. GOOD MOTOR THO.
Old 05-10-2004, 03:25 AM
montea's Avatar
tryn to learn
im guessing 170hp stock
if it were my car i would replace spark plugs, wires, cap, rotor, air filter, fuel filter, and any bad hoses/belts.
Old 05-11-2004, 12:22 AM
DoubleVision's Avatar
If the car sat that long then the gas has long turned into crap, so it`s no surprise the car doesn`t run too well, replace all the things mentioned in the before post, also replace the oxygen sensors. When you do the tune up, get the best pieces you can afford, get spiral core plug wires and not the cheap parts store solid core wires, also take your time and route the plug wires correctly. a K&N air filter would also be of benefit. Have the TBI injectors cleaned professionally or get a few bottles of the best fuel injection cleaner you can buy and run it through a few tanks of of fuel. It would likely be a good idea to get a can of sea foam, pour it in the oil and let the car idle 15 minutes then change the oil and filter. I would also pour some sea foam in the fuel to help clean the system. Lastly, since the car sat so long, it would be a good idea to change the tranny fluid and filter, even if the tranny seems to be on it`s last legs, one case I seen where one sat up the filter turned to mush so it was restricting the amount of fluid the tranny could pull in, therefore it slipped and wouldn`t shift correctly.
Old 05-28-2004, 12:55 PM
bullheimer's Avatar
NEVER use credit cards!
join the club
Old 05-28-2004, 12:59 PM
poncho62's Avatar
Wiki Edits: 5
Re: Damn im dumb need lots of help
Originally posted by bullheimer
join the club
You formin' a club, Bull?................my old lady says that I should join.
Old 05-31-2004, 08:21 AM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
Maybe instead of taking care of it you are just tearing it up. Why not check and SEE if the mounts are broke. Start fixing what ain't right.
Kevin
Old 05-31-2004, 09:58 AM
check your fluids
the tranny is probally slipping cause it is low on fluid I baught an older camaro like that for the engine and didn't care about the trans so dumped in a little fluid to get it on the trailer then when i got home blew the first gear on the 700r4 trying to do a brake stand but it still smoked the tires in reverse. drop the pan change the fluid and fill her up is what else i would do.
Jesse
Old 06-08-2004, 02:32 PM
ok thanx everyone but i just ran into a 1984 camaro for sale only $500 and it was a friends so i know everything about it.he just bought a 03' mach1 that he's taking to the track today sapposed to run 13.1 but i dont know hes not the best shifter out there.the camaro has a 350 out of an elcamino that ran 13.4 in the camaro 13.9,has a 350turbo trans and is in great condition just needs a new rear main seal. I think its a steal so for now the formula project is on hold for about 2 months unless i find some one to buy it.
Old 06-09-2004, 04:42 PM
Rubberman2003's Avatar
Nice find Brian,just dont get to many projects at once.
