Damper and Flexplate 28 or 50 oz. - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-22-2006, 04:55 PM
Hi guys.
Do anybody knows the exactly description on 28 oz.and 50 oz. on counterweights on dampers and flexplate for Ford Engines.I tought it was the weight of counterweights but is wrong because is imposible that the counterweight welded on the flexplate weights 28 or 50 oz.
If anybody knows,please let me learn about it.
Thank`s.
Old 02-22-2006, 10:38 PM
aka Duke of URL
Internal Engine:
This category primarily deals with engine balance. If you just built up a new motor, or bought a used one, and it has had a vibration from the minute you first fired it up, chances are the problem is in the balancing of the engine. Ford engines have used a variety of balance factors over the years. All small block Fords, including the 351C and 400M are externally balanced. However the early 221-302's used a 28oz. counterweight factor while recent years all use a 50oz. imbalance.
NOTE: Changed in 1981 production with introduction of 255ci.
This means you must use the same crank, harmonic balancer and flywheel or flexplate. The Ford FE's, 429 and 460 engines are all internally balanced, except, for the 410 and 428. Also the Ford truck series (FT) are all externally balanced, so keep this in mind if you are using the heavy duty forged steel cranks from the FT in your FE buildups. Using mismatched harmonic balancers, cranks, or flywheels is guaranteed to cause vibration problems. There is no two ways about it, it will occur, and it will be very noticeable. As a matter of fact, it will result in destroyed bearings in short order.
Small block Ford harmonic balancers and flywheels used 28oz counterweights in the early years then switched to 50oz. Mixing the two varieties will cause serious engine balance problems.
-VIBRATION ANALYSIS-FORD MUSCLE-
Old 02-23-2006, 08:12 AM
Thank`s for the information but like I said,I did solve the problem wich it was the flexplate.The question was where the 28 or 50oz are.On counterweights or where,because if you take off the counterweight that is welded on flexplate,that piece of stell does not weight 28 or 50 oz.
Old 02-25-2006, 12:19 AM
View 24 albums at Moes Garage
Its called an 'imbalance'...
and is measured at a certain preset rpm at a certain distant from the centre (of axis) of the flywheel.....
- 28 and 50 ounce 'imbalance' - (not counterweight) would therefor refer to xx grams or ounces of weight at x inchs from the center of axis at xxxx rpm.
The actual counterweight 'may' be 2 ounces of weight, but at x inches from axis times engine rpm you would get (28 or 50) ounces of imbalance.
The two terms "counterweight" and "imbalance" are not interchanable as "counterweight" refers to a 'static' weight (non moving) and "imbalance" refers to a 'kinetic' and in this case, 'rotating force'
moe
http://spaces.msn.com/moes-garage/
Old 02-25-2006, 12:25 AM
To further answer your question,
The imbalance is the weight on the flexplate ....
moe
Old 02-25-2006, 12:29 AM
"""Small block Ford harmonic balancers and flywheels used 28oz counterweights in the early years then switched to 50oz. Mixing the two varieties will cause serious engine balance problems. """
I dont know who your quoting but they used 28oz/50oz Imbalance not 28oz/50oz counterweights
moe
Old 02-25-2006, 03:07 AM
aka Duke of URL
I dont know who your quoting but they used 28oz/50oz Imbalance not 28oz/50oz counterweight.
And correct you are sir. Thanx for the detailed explanation. The quote only added to the reader's confusion.
The actual quote is from FORD MUSCLE MAGAZINE (referring URL in previous post) and I did not catch that detail. I would tip my hat but the resulting glare into your eyes may be the basis for a resulting lawsuit...
Am Looking For Factory/Aftermarket Speed Parts For The MEL (Merc-Edsel-Linc-TBird) Engine Family (383-410-430-462) Produced From 1958 To 1968
Also Early FORD Special Service Tools
-MEL ENGINE FORUM-
Old 02-26-2006, 01:53 AM
Kultulz,
I checked out the FORD MUSCLE MAGAZINE and there is a lot of good tech there.
With so many articles and so much tech there is bound to be the odd mistake.
(A recent flathead article in a popular Hotrod magazine was loaded with misconceptions..)
But Nobodies emune to screwing up. I take my turn often enough.
As far as the Ford Nuscle Magazine website goes, I checked around to see if there was a "feedback" button to report the mistake but no such luck. Not sure if you have to be a member or what. But Being that it is a Magazines website I expect a good amount of people view that link everyday, It begs for a correction.
By the way, good choice on playing with the MEL stuff. I wish I still had my 65 lincoln with the 462. But it's looonnnng gone.
cheers.
moe is in the garage
http://spaces.msn.com/MOES-GARAGE/
Old 02-27-2006, 06:29 PM
The "quote" is wrong in another way also. The 351W did not switch to 50 oz imbalance. It has been 28 oz all it's production life.
Small Block Chevy 400 flexplate install novajohnb Engine 2 10-31-2002 03:53 PM
