dana 300 transfer case - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-15-2006, 09:22 PM
inquiring_mind2's Avatar
a shade tree mechanic
Hello,
I am running a jeep in mud boggs. I am using a dana 300 transfer case. I was wondering if I could run the front end in high and the rearend in low. I want to have the front tires spinning faster than the rear ones. Can it handle the rpm's. I will be turning it about 6700 with a bbc..
Thanks,
Chris
Old 04-15-2006, 09:35 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
It wouldn't be a good idea, you'll end up grenading the transfer case.
You could try a smaller tire on the rear axle, or swapping the gears in the front axle to the next higher ratio.
All you are looking for is front-end float, and these are the best ways to get it.
I have also seen wider tires tried for this, but DON'T try this one, it's much easier to get out of control with the wides on the front, and too narrow will not keep you on top like you need to be.
What size tires are you running and what gear ratios do you have.
Old 04-15-2006, 09:38 PM
I am running 35 inch tires with 410 in front and back. I was just wandering on the transfercase because I have a twin stick shifter for it.
Thanks,
Chris
203 transfer case questions jesse01 Transmission - Rearend 21 04-04-2006 08:54 PM
dana 300 inquiring_mind2 Transmission - Rearend 2 11-19-2005 06:15 PM
Transfer Case Identification unstable Transmission - Rearend 13 07-03-2005 06:26 PM
chevrolet transfer case dbarnes Transmission - Rearend 2 12-22-2004 03:04 PM
Aluminum Transfer Case Bigdude_79 Transmission - Rearend 2 12-06-2002 10:23 AM
