Dana 35 drum/disk swap question - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-19-2005, 01:43 PM
New Member
I read the knowledge base and didn't see this question addressed. I'm installing the rear disks off of a 94 Ford crown vic with an 8.8 on my Jeep's dana 35. The bolt pattern is the same, but I had to grind off a little of the lower part of the axle flange to get the plates to mount flat. The new backing plate has a bracket that went up and attached to the crown vic's rear axle, I assume to strengthen the backing plate against torsional force. The bracket won't work on the Dana 35. The brackets too short and there's no place to attach it without welding a plate onto the axle tube.
Is this bracket an essential piece of hardware, or can I just deep six it without asking for trouble? I'm not going to use the anti-lock sensors, so there won't (hopefully) be any violent pulsations of the calipers.
Thanks.
Old 11-19-2005, 11:58 PM
Thanks.
Ford did not engineer it, make it and install it......unless it was necessary.....IMHO...
Rear End Swap Question Weimer Transmission - Rearend 3 05-20-2003 10:08 AM
454 swap question nitro junkie Engine 2 01-12-2003 08:32 AM
Ok can someone help me with a question about my engine swap plz? Rubberman2003 Engine 4 12-08-2002 08:55 PM
66 283 auto / 67 283 swap Question FasterPastor Engine 1 11-05-2002 01:48 PM
Gear swap question dion Transmission - Rearend 1 08-27-2002 09:26 AM
