dana 36 or 10 bolt - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-14-2011, 07:54 AM
dana 36 or 10 bolt
im thinking of putting a dana 36 corvette rear end in place of my 10 bolt ( 4.11s w/a locker). i figure the ride/performance will be better. my motor is a 454 BBC .30 over 750dominator with a victor intake and mid .500 lift cam. powerglide w/10 inch 3500 stall converter with manual valve body. do you think the dana will hold in my 67 impala?? pros/cons ??!!! i have the dana and the 10 bolt. a 9 inch or 12 bolt is not in the question just yet. the dana is just sitting there and would like to use it.
Old 11-14-2011, 01:36 PM
A D36 is very weak, partly due to the aluminum case and partly due to the small bearings and gears.
Ford 9" vs Dana vs Chevy 12 bolt wakisashi06 Transmission - Rearend 5 05-13-2011 06:11 AM
What is the difference between a Dana 60 and a Dana 61 onebadmerc Transmission - Rearend 1 09-20-2008 07:22 PM
5 on 5" rear end swap in my '62 GMC - 10 bolt vs 9" vs Dana 44 Chuck78 Transmission - Rearend 8 07-22-2008 10:01 PM
DANA 70 or 14 Bolt Full Floater Which is Better ? Rob Keller Transmission - Rearend 29 12-09-2007 09:53 PM
Dana or GM 12-bolt - which to pick leejoy Transmission - Rearend 6 09-13-2006 11:32 AM
