Dana 44, ring and pinion???? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-17-2002, 03:32 AM
deuce_454's Avatar
Post Dana 44, ring and pinion????
I am putting a jag rear suspension in my 32 ford, i am running a 700R4 and 275/60r15 The gearing i now 3.00:1 but i figure that with the 700r4 33% OD i can get away with running a 4.10:1 gearing.
noy for the big question, where can i buy dana-44 (which is inside the jag caseing)gears??? i havent been able to find them anywhere! many people sell the gasket sets and so on but not the gears and i absolutely refuse to buy them from jeguar, they charge almost 800USD for them, just because it says jag on the box it comes in...
Old 08-17-2002, 05:38 AM
roys63's Avatar
Thumbs up
Look in the new Jegs mag. page 151, Dana 44 is used in many 4X4s and Vett and Dodge Viper or go to, jegs.com
Old 08-17-2002, 09:38 AM
deuce_454's Avatar
Post
found it, thanx.. but if i want to mount a 4.10:1 no3 carrier, can i use some kind of spacer or is that the other way arrround??
Old 08-18-2002, 02:30 AM
roys63's Avatar
Thumbs up
Yes i think you will need a spacer or find a thick replacment gear set, you may find a carrier in junk yard from 60-70s front axels most were 4.10s with the manual trans.
