dana 44 to spicer - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-10-2010, 01:29 PM
jameshi's Avatar
71 ford high boy
dana 44 to spicer
hi i have to replace my old front axle and i have a new one the is a spicer and i dont no where to start i took my old one out and i seen that the spicer is bigger then my dana 44, the knuckle is bigger the the brake lines are dif, do i want to go back to stock or go with spicer i can get one or the other for 100 each
0one of them are going in to a 71 ford f250 high boy
Old 06-10-2010, 08:24 PM
prostreet6t9's Avatar
Differential/Driveline
Dana and Spicer are one in the same. There is a 7 Digit number that starts with a 6 stamped on the front of the drivers side axle tube. The last number indicates the ratio the diff was made with. If you give me the first 6 numbers I can tell you anything you need to know about the diffs.
Old 06-10-2010, 09:33 PM
jameshi's Avatar
71 ford high boy
the numbers are 603396 on the spicer and 603304 on the dana
Old 06-11-2010, 08:18 PM
jameshi's Avatar
71 ford high boy
is that the numbers
Old 06-12-2010, 03:23 PM
Sorry I missed your post. Yes that looks like the numbers. I won't be back at the shop till Monday. I will look them up then.
Old 06-12-2010, 06:24 PM
jameshi's Avatar
71 ford high boy
Ok thank u that will really help
Old 06-13-2010, 03:44 PM
603396 - 44 - Front - 1973-75 F-250 Heavy Duty (Part-time Transfer Case)
603304 - 44 - Front - 1972 F-250 (Part-time Transfer Case)
both apear to be dana 44's the 396 by the numbers is new and heaver duty should work good for you
Old 06-13-2010, 06:24 PM
jameshi's Avatar
71 ford high boy
ok thank u
Old 06-14-2010, 10:44 AM
Kandyman is correct. The 603304 only has 1310 inner axle u-joints and the 603396 has 1350 inner axle joint. Both have 30 spline inner axles.
Old 06-14-2010, 01:10 PM
jameshi's Avatar
71 ford high boy
are the brake the same in both
Old 06-14-2010, 02:40 PM
Unfortunately The Spicer books only list from the Wheel Brg's in as far as parts. You could hit up your local parts store with the info listed above and they could tell you if they brake's the same.
Since these are a closed knuckle set up you should have drum brakes.
Old 06-14-2010, 05:52 PM
The brakes are the same if drum brakes. The 396 number is listed as a 3500 lb axle, the other one is a 3000lb axle. Difference is in the knuckles.
Old 06-12-2011, 09:41 AM
just a side note.......the dana 44 gears ----crown and pinion are also used in Jaguar rear ends 1960 to 1984 with ratios from 2.79 too 4.54.
mike
Dana 44 - How strong are they? 31fordcoupe Transmission - Rearend 4 06-29-2009 01:40 AM
5 on 5" rear end swap in my '62 GMC - 10 bolt vs 9" vs Dana 44 Chuck78 Transmission - Rearend 8 07-22-2008 11:01 PM
Dana 44 rear upgrades or swap - 1962 GMC 1/2 ton Chuck78 Transmission - Rearend 2 07-14-2008 05:30 PM
Dana 44 Skunk Transmission - Rearend 1 01-30-2005 01:35 PM
Dana 44 Skunk Transmission - Rearend 1 11-28-2004 06:57 PM
