Dana 60 decoding help needed - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-25-2008, 12:43 PM
Last journal entry: the beginning
I have a dana 60 and I need help decoding it, the codes are:
c34155
1 20 76 DANA 32626 B3D22X 37 6
Please help me decoding this differential.
Stephen
Old 10-25-2008, 03:53 PM
prostreet6t9's Avatar
Differential/Driveline
c34155
Stephen
Those must be off the ring gear or pinion gear,Looks like 617 ratio. What all where you wanting to know?
Old 10-25-2008, 05:11 PM
I was wanting to know what year it is, its rarity, and if you would know what it is worth that would be great. Thanks
Old 10-25-2008, 06:40 PM
When looking at the housing from the cover side there will be a series of numbers stamped into the right axle tube. The first series of numbers will be the date of manufacture. For example, 1 20 76 would be january 20th 1976. The second series of numbers (beginning with a 6) is the bill of material number. Post the bill of material number and I can be more help. mudlust.
Old 10-25-2008, 07:00 PM
there is no code on the axles tubes. It was raced and cut on so I think it is welded over. Are there any other things you can tell me? Thanks
Old 10-25-2008, 08:25 PM
Prostreet6t9 is correct. The numbers 32626 are the ring gear number and indicate a 6.17 ratio, 37-6 is the tooth combination, and 1 20 76 is the date of manufacture. I had a Dana 60 cut down for my Jeep. The ends were cut off and new ones were installed to accomodate larger spline axle shafts and the numbers are still visible as they are closer to the housing side of the tube. If you look at the tube you will see where it was milled to slide into the housing. If the numbers are still present they should be just past the milling line. If you had the bill of material number, I could probably tell you which motor company it was manufactured for, what years and what models, as well as how many were produced. Without it I cant tell you anything else.
dana 60 axles cowtipper Transmission - Rearend 8 10-31-2008 07:08 AM
Dana 60 cowtipper Transmission - Rearend 13 10-17-2008 05:52 PM
dana 60 DeathByGreaser Transmission - Rearend 5 11-24-2002 10:26 AM
Dana 60 Ring Gear Spacer Chezelle Transmission - Rearend 1 11-10-2002 11:17 AM
dana 60?? Necro Transmission - Rearend 4 10-12-2002 04:41 PM
