Dana 60 I.D. help - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-12-2011, 03:30 PM
Dana 60 I.D. help
I have a 1959 Chevy pickup that does not have the orig rear end. I do know its a dana 60 posi. Does anyone know what manf and year 6 lug dana 60s were installed? i need brake drums.
Old 06-13-2011, 09:18 AM
Barry.M's Avatar
Old Phart
Last wiki edit: How to identify a Ford V8
Last journal entry: 27 T Roadster project-For Sale
Wiki Edits: 3
Try this link for identifying that Dana 60.
http://www.therangerstation.com/tech...M_numbers.html
It only goes back to about 1977 though. Also check the Dana website, has similar info. Once you know the BOM number on the housing you may get somewhere with parts etc..
Hope this helps............Barry
Old 06-13-2011, 10:05 AM
Thx for the link. Whats the difference btwn full & semi floating? Which is better?
Old 06-13-2011, 12:23 PM
prostreet6t9's Avatar
Differential/Driveline
If you get the BOM # off your housing I can tell you what it came out of.
Old 06-14-2011, 02:59 AM
Barry.M's Avatar
Old Phart
Wiki Edits: 3
G'day tjet,
Full floating axles have a greater load carrying capacity than semi-floaters.
They are recognizable by a hub protruding through the wheel centre with a number of bolts. This is the removeable axle. Trucks over about 1 ton carrying capacity generally have full floating axles. The Brake Drum and Wheel Flange Hub assembly runs on bearings which fit on the axle housing. The axle housing handles the mass/load being carried and the Full Floater axle merely transmits the power to the wheel. A Full Floater axle can be removed without removing the wheel itself as it unbolts from the wheel hub.
Semi floating Dana 60's are like a regular diff. The axle pulls out with the brake drum after removing the wheel. Semi-floater Dana 60's were used in Dodge/Plymouth/Chrysler Hemi products of the 1960's, plus other applications that I'm sure other users here can tell you about. There is no difference in Ring and Pinion strength on a Full Floater or Semi Floater. The main difference between a semi-floater and say a 9" Ford diff for arguement sake is that the semi-floater axle is retained by "C" clips within the diff centre. A real pain in the bum if you break an axle as the whole lot can "pop out" , unless you have installed a "C" clip eliminator kit or other axle retainer.
Dana 70's which look the same as Dana 60's until you know what to look for are slightly larger again in the ring and pinion and axle department and consequently, a bit stronger. Dana 70's are mostly used in Dual wheel applications like F350's etc. and some Extra Heavy Duty Pickup truck applications like "Camper Specials". As far as I am aware ALL Dana 70's are full floating axles......however I have been wrrrrrrrrooooong before !
I'm sure there will be many "Hotrodders.com" members who will be able to tell you far more about which Full floaters and semi-floaters came in what vehicle.
The Dana axle ID located on the right hand axle tube (BOM as pointed out by prostreet6t9) will tell you what application it was used in. Also the ID tag located on one of the diff cover screws (unless it has been removed) will tell you what ratio it is and if it's an LSD or not.
Cheers..........Barry.
Old 06-14-2011, 07:12 AM
Last journal entry: A few ongoing projects
"...... Semi-floater Dana 60's were used in Dodge/Plymouth/Chrysler Hemi products of the 1960's, plus other applications that I'm sure other users here can tell you about......."
As far as I know the only factory Semi-Floating Dana 60 were in the Hemi/HP 440 4 Speed Dodges/Plymouths. As such they are reasonably rare and relatively expensive (compared to the full floating (truck) Dana 60s or comparable Ford 9" and GM 12 Bolt rear ends). The picture below is my 69 B Body Dana. As it sits its probably a $1200-1400 rear end...... maybe a bit more if someone is hunting a specific date code.
In the case of the Mopar passenger car Dana 60s the axels do NOT use the a C clip retainer but rather a press on bearing and bearing retainer like a 9" Ford or Mopar 8 3/4 (it actually uses the same bearings as the 8 3/4).
Because of the high demand for semi floating Dana 60s by the Mopar crowd and relatively low cost of used full floating Dana 60 housings there are a couple of outfits that are converting the truck Danas to passenger car use.
Old 06-14-2011, 07:58 AM
Barry.M's Avatar
Old Phart
Wiki Edits: 3
Now isn't that a pretty sight............Hemi and Dana in the same pic.....
Old 06-14-2011, 10:46 AM
There is some Dana 60 semi float diffs in the late 60's Chev 1/2 ton trucks. They are getting pretty hard to find and bring a chunk of money.
Old 06-14-2011, 12:16 PM
Great info. I will check the numbers on it. I think its out of a 60s GMC
Old 06-14-2011, 05:53 PM
Here's the best pic I have of the rear end. I need to take more photos
Old 06-15-2011, 07:32 AM
cranky1's Avatar
Just stuck
The BoM number is located on the right side axle tube and is usually centered and about 2-3" away from the center section.
In the mid 60's, you could special order a semi floating Dana 60 in a 1/2 pickup but not many opted for it and I would imagine you could do the same with GM too? Anyway, the full float 60's were common in 3/4 ton pickups all though the 70's but sometime in the late 80's (?) the OEM's started building them as semi floating unless it was ordered with limited slip. At least that's the way it was with Dodge during the 90's. Ford went with a '501' housing....a Dana 60 with smaller axle tubes and semi floating axles.
Old 06-15-2011, 10:40 AM
I now understand the difference between full and semi floating. Does a semi floating dana automaticly mean posi, or is that another option?
Old 06-17-2011, 09:06 AM
cranky1's Avatar
Just stuck
During the 90's a full floating axle on a Dodge usually means it has a posi but not always. Years past, all Dodge 3/4 ton pickups had full floaters but that's not the case these days but if you ordered a limited slip, it would mean you got the full floating axles. I have no idea what they are doing after around 2000...
What is the difference between a Dana 60 and a Dana 61 onebadmerc Transmission - Rearend 1 09-20-2008 08:22 PM
Dana 44 Skunk Transmission - Rearend 1 01-30-2005 01:35 PM
Dana 44 Skunk Transmission - Rearend 1 11-28-2004 06:57 PM
Dana 44. Skunk Transmission - Rearend 1 11-09-2004 09:13 AM
dana 60 5 lug g.b. Transmission - Rearend 1 01-03-2004 07:30 PM
