Dana 60 interchange - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-20-2010, 02:05 PM
Dana 60 interchange
I have a 1977 F250 4x4 highboy (narrow frame divorced xfer case). A few years back a wheel bearing failed on the rear axle, and friction welded itself to the spindle. I cut the old bearing off and reshaped the spindle with a file until the new bearing fit. I haven't had any problems with it, but it's always worried me.
I bought a bare d60 housing with the carrier caps from a guy for $50. I looked up the bom number for it and it came up 1971-72 f250 hd 4x2 pick up. The bom # is 603196 11. Will this housing work in my truck?
I would like to got to my local u pull wrecking yard and get a carrier from another truck and rebuild it, what years will interchange with this housing. I think my truck has 30 spline axles and would like to reuse them as well as the backing plates and brakes.
I'm also thinking about looking for a powerlok. I know there not the best but I will be using the truck to hual a camper and winter driving, not much off road.
Mike
Old 12-20-2010, 08:53 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
i'm curious as to what your concerns are about the original axle?
is it that it got to hot and is no longer strong enough?
Old 12-20-2010, 09:33 PM
I guess I'm just worried it might spin the bearing and weld to the spindle again. I'm planning on packing a large camper around and do not want to have problems far from home.
Old 12-20-2010, 09:38 PM
& matts38chev
if the bearing fit ok it should be fine.
was it kinda loose?
Old 12-20-2010, 10:23 PM
I'd had some problems a few years back and peened the spindle to make the bearing fit better, but I can't remember what the problem was. then last year the seal up against the spindle started leaking and I found a speedy sleeve to fit it, but its leaking a little again.
Old 12-20-2010, 10:27 PM
& matts38chev
if the seal is leaking that probably an indication something is not right.
sounds like your starting to get a new axle together might be a good idea
Old 12-21-2010, 03:02 PM
So any idea on the carrier interchange? I would think 73-79 ford for sure, and I'm thinking early 80's ford, maybe.
Dodge Dana 60 front hub conversion automods Transmission - Rearend 0 01-06-2009 05:01 PM
What is the difference between a Dana 60 and a Dana 61 onebadmerc Transmission - Rearend 1 09-20-2008 07:22 PM
Dana 60 decode ? camaro1212 Transmission - Rearend 1 04-08-2008 05:59 AM
Welding Dana 60 D200Dodge Transmission - Rearend 5 02-05-2005 08:30 PM
Dana 60 pumpkin interchangeability wp442 Transmission - Rearend 5 09-05-2003 03:21 PM
