Dana 60 Power Lock Re-build help - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-16-2008, 06:30 PM
I'm not a Dana 60 guy, more familiar with GM 10/12 bolts.
However, my project came with a narrowed Dana 60 with what I think is a Power Lock rearend, 1966 vintage.
Has Strange axles, unknown spline count until I remove the third member.
A couple of pictures:
It appears to need a rebuild, as the wheels spin in opposite directions.
Anyone have re-build instructions?
Where's the best place to get clutches, etc? Mark Williams appears to have them for about $100.
Any gotcha's to look out for when tearing it apart, other than marking the cases before splitting them?
Many thanks.
Old 12-16-2008, 08:06 PM
prostreet6t9's Avatar
Differential/Driveline
Those are Great posi unit's! and that is a power lock, Very straight forward to replace clutch's,The clutch kit usually has the 2 pack's separated so it's easy to know what goes on each side. You will see 1 friction on each side that has a small hole in the tab,Make sure that friction goes against the clutch hub as it is a oil lube hole.
Other than that just make sure the side gear splined thru all the clutches before you bolt the 2 halve's together.
The part number for the clutch pack is Dana 707075X if you wanna do some shopping.
Old 12-17-2008, 07:24 PM
Thanks for the part number for the clutch pack. With that little piece of data, I've found a lot of info...!
I'll be tearing into it over the holidays.
Greatly appreciated!
Old 02-07-2009, 06:18 PM
Update:
Got the Dana out of the Nova:
Tore it apart, and found I have bigger/more problems than the posi. Bearings welded in, o-ring seals gone, someone used orange RTV! to seal the axle bearings:
Other things found bad - PS side bearing housing in a degree or 2 crooked, wrong backing plates, wrong brake drums, one crooked lower shock mount
Took it to my local axle/diff guy who knows his stuff.
List of mods/fixes:
  • New Moser axles
  • New PS outer bearing housing
  • New outer bearings
  • Posi fixed
  • Wheelie bar mounts cut off
  • Old panhard bar mount cut off
  • New bottom shock mounts
  • Correct backing plates
  • Correct brake drums
  • New rear brake lines
  • Rear ladder mounts boxed
Shocks were shot, too:
So I bought a set of slightly used QA1's.
My $100 dollar rear end project is going to cost me around $1,500!
Old 02-07-2009, 06:50 PM
Sorry to hear about that! Its only money right? Ha Ha. At least thats what I try and convince myself when that happens
Maybe a good time for some rear disc brakes?
Old 02-07-2009, 07:07 PM
Yeah, I keep telling myself that!
I would do rear discs, but I'm already set with a disc/drum master cylinder setup...
Dana 60 pumpkin interchangeability wp442 Transmission - Rearend 5 09-05-2003 03:21 PM
Ford 9" Vs. Dana 60 79 Poncho TA Transmission - Rearend 3 08-29-2003 07:42 AM
dana 60 DeathByGreaser Transmission - Rearend 5 11-24-2002 09:26 AM
Dana 60 Ring Gear Spacer Chezelle Transmission - Rearend 1 11-10-2002 10:17 AM
dana 60?? Necro Transmission - Rearend 4 10-12-2002 03:41 PM
