Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Dana 60 Question
Old 02-18-2011, 01:10 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by Barnestormer
Does anyone know if there is an axle shaft kit out there that can be used to fit wheels with the GM 5 x 4 3/4 bolt pattern to a Dana 60? If not, are there rear axles out there with this bolt pattern stronger than the 10 bolt?
Thanks for looking!
There are wheel adapters that bolt to the axle flange that allow the use of a different bolt pattern wheel. This changes the wheel position inside the fender/wheel well, so the wheel/tire fitment when using the adapters has to be checked and verified that they will fit as they should. Good adapters (the only ones you shoud even consider) cost nearly as much as some wheels.
The best plan would be to buy new axles for the D-60 w/the 5 on 4.75" pattern, IMHO.
