Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Dana 60 Question
Old 02-18-2011, 12:11 PM
big gear head's Avatar
big gear head big gear head is offline
High Performance Rear Ends
It depends on how the Dana 60 is built. If it has the full floating axles then you can't use those wheels. If it has semi floating axles then you can get axles with any bolt pattern that you want. If it is full floating you can convert it to semi floating by changing the housing ends. This requires a housing fixture and good welding skills.
