Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Dana 60 Question
Old 02-19-2011, 07:20 PM
big gear head's Avatar
big gear head big gear head is offline
High Performance Rear Ends
Do you have the Dana 60 with semi floating axles or full floating axles? If you have semi floating axles then Moser can make a set to replace what is in it now. If you have full floating axles then the housing will have to be modified to use the semi floating axles. That is where the housing fixture and welding skill comes in. You will have to change the housing ends and then order custom axles.
