dana 60 rear end #602927-15 - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-02-2011, 01:14 PM
I have been looking for 2 days and cant find anywhere to Identify this rear end I was told it came out of a chevy but when ordering seals they were wrong ones twice, I know I can measure seals and get them that way but would like to know what year and make it is.There are more numbers on passenger side :4 25 8 c 2 23 8bl(or 1) 602927 15 the 2 in the 602927 could be a 3 I can't read it good enough it also has a 9.75 ring gear and a detroit locker if this helps. any info would be much appreciated thanks roger
Old 08-02-2011, 02:00 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Mounts
According to this chart from DANA Corp, on page 142 (#148 of 252 in the PDF)
602927-15 was a DANA 60, O.E. on a 1968 C20 with leaf springs.
3.54 ratio
NOT a posi.
According to this same chart, (pg 151) this same axle was used on a 1967 GM "I1500" ... which I've never heard of.
OK ... using that information above as the basis for application data,
I went to SKF/CR Online Catalog
and found C/R Part# 23844
Part Detail - 23844
Shaft 2.3750
Outer Diameter 3.8810
Bore 3.8760
Width 0.4380
Construction CRWH1 (Single Lip)
Name:	Seal Types.jpg
Old 08-02-2011, 04:51 PM
prostreet6t9's Avatar
Differential/Driveline
Along with that CR#. You can also use Spicer#35697 or National 455860
Old 08-08-2011, 10:59 AM
60 dana
I did more research and it is a 67 chev 1500 6 bolt origanally and someone has put 8 lug axles and a detroit locker in it thanks so much for the info have a GREAT DAY Roger
Is a Dana 60 to much rear?? obengston Transmission - Rearend 26 01-09-2010 09:16 AM
Dana rear end cover same as on Jaguar? staleg Transmission - Rearend 2 09-03-2008 11:26 AM
dana 60 rear mike's hotrods Transmission - Rearend 1 12-06-2007 08:22 PM
dana 60 or 8 3./4 rear axle legionlleh Transmission - Rearend 7 03-11-2007 08:44 PM
dana 44 rear posi. or not pocket change Transmission - Rearend 0 02-25-2003 04:29 AM
