Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Dangers of High Amp Output
Old 12-06-2004, 12:31 PM
Ironman's Avatar
Ironman Ironman is offline
The fans are on a relay and are rated at about 10 amps each for a total of 20 amp of draw. The charging system has been upgraded to a Chevy alternator, which may still need to be upgraded again as I put more load on it. I also have installed an optima battery which increases the cranking amps over the original battery. My main concern was the wire gauge and the amp meter's durability. If willys36 is running high amps with his stock wiring and gauges that make me feel a little more comfortable. Thank you for your responses.
