Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Dangers of High Amp Output
Old 12-06-2004, 02:48 PM
willys36@aol.com's Avatar
willys36@aol.com willys36@aol.com is offline
Wiki Edits: 21
I used stock wiring until about a year ago but have since rewired it with an EZ harness. Still plan on using the stock amp meter though. A '65 harness is new enough that it was designed to handle several accessories in the high end models so should handle your upgrades with ease.
