-   -   dark oil? (http://www.hotrodders.com/forum/dark-oil-47562.html)
onecoomofo 09-11-2004 06:17 PM
dark oil?
I have a motor I just built, and for some reason the oil gets very dark/black about 100 miles after I change it. Is this normal or does it have something to do with the blowby on the rings getting into the oil? For some reason i don't think we lined up the rings correctly when we rebuilt it?
- Sean
killerformula 09-11-2004 06:23 PM
are you losing oil? hard starts? compression test? <--- only getting into it will answer your questions. Trouble shoot it-
K
onecoomofo 09-11-2004 06:31 PM
Not its actually not leaking any oil at all, which isn't normal with me so I'm happy about that. Starts just fine. It runs great. Sounds great. Just dark oil. However, I'm no expert at looking at oil, this is the first motor i've built. What all causes the oil to get dark this quick?
-Sean
oldschoolrods 09-11-2004 08:08 PM
Is your engine running rich? Carbon will cause the oil to get dark.
crazy larry 09-11-2004 08:22 PM
What kind of assembly lube did you use? I noticed what looked like moly-type lubricant in my oil after the first 2 oil changes..... haven't noticed it anymore......
tresi 09-11-2004 08:43 PM
How many miles are on it and how many time have you change the oil? If the ring haven't seated yet the oil will turn black really quick. part of this blowby and part of it is the microscopic metal particles from the rings and cylinder walls.
