dark oil? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-11-2004, 07:17 PM
onecoomofo's Avatar
dark oil?
I have a motor I just built, and for some reason the oil gets very dark/black about 100 miles after I change it. Is this normal or does it have something to do with the blowby on the rings getting into the oil? For some reason i don't think we lined up the rings correctly when we rebuilt it?
- Sean
Old 09-11-2004, 07:23 PM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
are you losing oil? hard starts? compression test? <--- only getting into it will answer your questions. Trouble shoot it-
K
Old 09-11-2004, 07:31 PM
onecoomofo's Avatar
Not its actually not leaking any oil at all, which isn't normal with me so I'm happy about that. Starts just fine. It runs great. Sounds great. Just dark oil. However, I'm no expert at looking at oil, this is the first motor i've built. What all causes the oil to get dark this quick?
-Sean
Old 09-11-2004, 09:08 PM
oldschoolrods's Avatar
Last journal entry: Engine Compartment
Is your engine running rich? Carbon will cause the oil to get dark.
Old 09-11-2004, 09:22 PM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
What kind of assembly lube did you use? I noticed what looked like moly-type lubricant in my oil after the first 2 oil changes..... haven't noticed it anymore......
Old 09-11-2004, 09:43 PM
How many miles are on it and how many time have you change the oil? If the ring haven't seated yet the oil will turn black really quick. part of this blowby and part of it is the microscopic metal particles from the rings and cylinder walls.
