Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Darn bolt won't come loose
Old 08-14-2012, 05:22 PM
rusthater89's Avatar
rusthater89 rusthater89 is offline
This is one of those hex key type bolts on a 78 firebird frame. It is one of two that hold the sway bar to the frame.
My problem is when I try to remove the bolt the female end that the bolt screws into keeps turning as well. I thought of reaching it from the inside with pliers or something to hold the female end from moving but there is a piece of metal blocking my way as well as inserts for the power steering bolts.
ID:	67410   Click image for larger version
