Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Darn bolt won't come loose
Old 08-14-2012, 07:22 PM
rusthater89's Avatar
rusthater89 rusthater89 is offline
I do not know the correct terminology so pardon any confusion.
The red lines point to the power steering bolts. They have these inserts that run through the frame. There is also a metal plate in that area that also hinders any access to the inner part of the bolt. The yellow line points to the "insert" or "nut" of the bolt that I am trying to remove. When I try to turn the bolt counter clockwise(as in tryna remove it) The "insert" that the bolt threads into turns counter clockwise with the bolt hence my problem with the bolt not coming out. the blue line is of course the bolt.
I basically need a way to keep the insert that the bolt threads into from moving so I can undo the bolt.
