Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Darn bolt won't come loose
Old 08-15-2012, 07:04 PM
66GMC's Avatar
66GMC 66GMC is offline
Get in, sit down, hang on
Last journal entry: Cab Removal
Originally Posted by rusthater89 View Post
If I saw it off then how am I gonna put it back together when there is still half a bolt inside the hole? Also how am I gonna use a 9/16 wrench when the bolt head is one of those that require the use of an allen key or hex socket. Also the inside that you tell me to reach is not a nut. It is an insert with threads to accept the bolt. A wrench will not work on any of this.
The bolt head looks like this pic.
Well, I did figure out / understand the "socket-head cap screw" part, but assumed there was a standard hex-nut on the backside ... and that is what I was suggesting could be held with a wrench.
I'm not 100% sure of the correct name of those insert-nuts, but I call them "riv-nuts" or "nut-serts". They are commonly used to hold mirrors on the side of a door, luggage-racks on a trunk lid, etc.
I gotta say that I have never seen them used on a cross-member. That is usually nut-and-bolt or rivet territory.
