Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Darn bolt won't come loose
Old 08-16-2012, 07:42 AM
rusthater89's Avatar
rusthater89 rusthater89 is offline
Originally Posted by MRTS33 View Post
Someone must have striped out those holes and put the nut insert in there. Which is alright I guess. I would tach weld them in there though and chase the treads with a tap and use regular bolts with a dab of never siz on them. Don't know about that bent piece. Where did it come from? What are you tring to doing with th fuel line?
Well as you saw I did use my stick welder to weld them in place. When I blast the frame It should clean out the inserts.
The bent piece was bolted to the back of the sub frame on the passenger side.
I want the fuel line removed. If you noticed from the pics my frame is bare. I need to remove it from the body to sand blast. This Trans Am is gonna be restored.
