It looks like you could get a sawzall blade in between there.
![]() The other option might be to buy a cheap 9/16" open-end wrench and then bend or cut it in such a way that you could sneak it in there, slip it on the head of the bolt, then jam it up against the frame rail? |
The bolt head looks like this pic. Last edited by rusthater89; 08-14-2012 at 07:28 PM. |
I do not know the correct terminology so pardon any confusion.
The red lines point to the power steering bolts. They have these inserts that run through the frame. There is also a metal plate in that area that also hinders any access to the inner part of the bolt. The yellow line points to the "insert" or "nut" of the bolt that I am trying to remove. When I try to turn the bolt counter clockwise(as in tryna remove it) The "insert" that the bolt threads into turns counter clockwise with the bolt hence my problem with the bolt not coming out. the blue line is of course the bolt. I basically need a way to keep the insert that the bolt threads into from moving so I can undo the bolt. Last edited by rusthater89; 08-14-2012 at 07:30 PM. |
I pulled out my stick welder and just welded the darn insert in place. I also did it for another one that was having the same issue.
Does anyone know what this piece of bent up metal is? It was attached to the passenger side, rear part of the frame. Is there any other way to remove this fuel line hose without cutting it or using a hook tool? |
![]() I'm not 100% sure of the correct name of those insert-nuts, but I call them "riv-nuts" or "nut-serts". They are commonly used to hold mirrors on the side of a door, luggage-racks on a trunk lid, etc. I gotta say that I have never seen them used on a cross-member. That is usually nut-and-bolt or rivet territory. |
Someone must have striped out those holes and put the nut insert in there. Which is alright I guess. I would tach weld them in there though and chase the treads with a tap and use regular bolts with a dab of never siz on them. Don't know about that bent piece. Where did it come from? What are you tring to doing with th fuel line?
The bent piece was bolted to the back of the sub frame on the passenger side. I want the fuel line removed. If you noticed from the pics my frame is bare. I need to remove it from the body to sand blast. This Trans Am is gonna be restored. |
The retaining nut you refer to are indeed "riv nuts" (actually rivet nuts) and they basically work like a pop rivet. The tightening of the bolt expands the rivet nut in the hole to hold it tight. They are used in a blind hole (no access to the back side of the structural material). The easiest way to remove a stuck bolt from a riv nut is to apply continuous upward pressure between the attached item and the base it's attached to. A cold chisel or screwdriver usually works. Then spin the bolt off with a impact wrench. One of two things usually happens. Either the bolt come out or you pull the riv nut completely from the hole. It really doesn't matter because the parts off. The trick is how fast the impact turns the bolt.
BB |
| Fixing loose GM steering column - what bolt torque? | 75gmck25 | Suspension - Brakes - Steering | 1 | 02-05-2012 10:04 AM |
| Question about loose axle in Chevy 12 bolt rear end | heyjude076 | Transmission - Rearend | 5 | 07-09-2010 10:05 PM |
| the bolt won't budge! | lovelylady | Electrical | 5 | 10-17-2003 09:17 PM |
| Heck! I need help too darn it? | 4 Jaw Chuck | Hotrodders' Lounge | 15 | 03-06-2003 11:59 AM |
| darn points | rustyrazer | Hotrodders' Lounge | 14 | 12-24-2002 09:47 AM |
