Dart BBC Aluminum Heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-20-2006, 02:49 PM
jakejake1966's Avatar
Hello,
I purchased a set of the Dart BBC PRo 1 Aluminum heads and was wondering if anyone has any suggetions or input on gaskets,bolts,and spark plugs. Like which type of plugs,gaskets, should anti seize be used on them,etc. Also if you bought a set of aluminum heads is there anything you would have done differently or any advice to prolong the life of the heads?
Thanks
Old 02-20-2006, 02:55 PM
coldknock's Avatar
You should have a spec sheet with the heads with all that information on it. It comes with the heads.
Larry
Old 02-20-2006, 05:28 PM
496hotrod's Avatar
dart heads
What cc intake runners do you have? And what cubic inch motor are you installing them on? How much compression are you running?
Old 02-21-2006, 09:48 AM
dart heads
I have the spec sheet but I was just wondering if anyone that uses aluminum heads has any do's or don't, basically I am just trying to learn from someone else's problems and knowledge.
The engine is a 454 bored .060 over with .340 dome pistons, the heads are 355 cfm.
Old 02-22-2006, 05:52 PM
496hotrod's Avatar
heads
There are no special instructions except head bolts have to have washers, and use anti sieze on spark plugs. The 355 intake runners are very large for a street car, but other than that they will be fine.
Old 02-22-2006, 05:53 PM
496hotrod's Avatar
heads
Also, when buying head gaskets make sure they are for aluminum heads.
Old 02-23-2006, 07:27 PM
heads
Thanks for the information, I will post and let you know how everything turns out.
Thanks again
Dart Iron Eagle or Vortech Heads bigjoedo Engine 31 05-14-2013 05:36 PM
Flow Charts for Dart Heads Flywhel Engine 7 01-06-2006 02:26 PM
New Dart heads disassembled for inspection TurboS10 Hotrodders' Lounge 5 12-30-2004 04:52 PM
dart heads richardson110 Engine 7 12-19-2004 12:14 PM
BBC Heads, Valves size, harden seats ??? Impala5967 Engine 1 10-01-2003 08:27 PM
