-   -   dart iron eagle blocks (http://www.hotrodders.com/forum/dart-iron-eagle-blocks-118315.html)
pth 06-17-2007 10:01 AM
I built a new 427 s.b. with the iron eagle,,,Problem,,,the starter sits to far back when bolted on?? the gear on the starter is just into the gear on the flex plate.. anybody ever hear of something like this Help.... :mad:
madgrinder 06-17-2007 11:10 AM
Flexplate on backwards???
pth 06-17-2007 12:04 PM
re: iron eagle block
I only wish it was that simple!!! But thanks for the thought,, Its strange cause I had that crank and that starter in a different block and all was well! so the new block could be the problem??? thats a crazy thought
harryman 05-25-2008 03:31 PM
starter problems
Hey man I just ran into the same problem with my sbc iron eagle block what do you have to do to fix the starter issuses will you let me asap if possible
thank you harryman :confused: :confused:
