Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Dart Iron Eagle Heads For a 383 stroker
Old 01-04-2005, 02:21 PM
ROB WEST ROB WEST is offline
New Member
the best thing to do is to contact the maker of the heads and go thru the build up with them,
my 383 stroker was about the same as yours air flow research heads, i contact dart and edelbrock, with afr head i chassis dyno at 518 fl lbs at the flywheel and 413 ft lbs at the rear wheels, strokers like to breathe, and that is what you are looking for
