-   -   Dart Iron Eagle Heads For a 383 stroker (http://www.hotrodders.com/forum/dart-iron-eagle-heads-383-stroker-55406.html)
truckster69 01-04-2005 01:58 PM
I just built a 383 stroker motor and it has KB197 pistons. I have a crane Xtreme Energy Hydraulic Flat Tappet Camshaft Lift: .490''/.490''
Duration: 274°/286°
RPM Range: 1800-6000.
And i was thinking of getting some 72cc Dart Iron eagle Heads for it. I was just seeing if anyone could tell if that would be the thing to do. Or what other heads would be good for my motor??
willys36@aol.com 01-04-2005 02:21 PM
Welcome. Being new to the site, you need to be sure to read the "Read Me' posts at the beginning of each forum. The ones here for example recommend that you just post a general introduction here and post tech questions in the appropriate tech forum, "Engine" in this case. This will give you the best chance for a good answer.
ROB WEST 01-04-2005 02:21 PM
the best thing to do is to contact the maker of the heads and go thru the build up with them,
my 383 stroker was about the same as yours air flow research heads, i contact dart and edelbrock, with afr head i chassis dyno at 518 fl lbs at the flywheel and 413 ft lbs at the rear wheels, strokers like to breathe, and that is what you are looking for
poncho62 01-05-2005 02:10 PM
moving to engine forum............
