Welcome. Being new to the site, you need to be sure to read the "Read Me' posts at the beginning of each forum. The ones here for example recommend that you just post a general introduction here and post tech questions in the appropriate tech forum, "Engine" in this case. This will give you the best chance for a good answer.
the best thing to do is to contact the maker of the heads and go thru the build up with them,
my 383 stroker was about the same as yours air flow research heads, i contact dart and edelbrock, with afr head i chassis dyno at 518 fl lbs at the flywheel and 413 ft lbs at the rear wheels, strokers like to breathe, and that is what you are looking for |
moving to engine forum............
Ontario Rodders |
