Dart Iron Eagle Platinum 200cc Guesstimate.
I am planning to build a motor for a pickup of mine and was hoping somebody could run a dyno sim of some sort for me if possible. I would do it myself but i have a mac
.350 block bored +.060 Probe forged pistons 6 inch Scat rods Stock 3.48 stroke crank Lunati 60103 flat tappet cam In .489 lift Ex. .504 Adv Duration 268 Intake 276 Exhaust .050 tappet lift duration In. 227 Ex. 233 Dart iron eagle platinum 200cc 2.02/1.6 heads Edelbrock Performer RPM intake 9.73 Compression ratio. .015 head gasket .025 piston down hole Equals .040 quench Quadrajet carb good for 850cfm will have small spacer under carb. stock bearing clearances. Just a street/strip motor for fun to build just want to see a dyno graph or even some good guestimates. im hoping for arund 400 horse or more if possible. I may switch to a single plane Victor Jr. Intake if the streetability is OK. Thanks, Logan |
Forgot to add 1 3/4 hooker full length headers into dual 3 inch pipes with dumps after the collectors and hooker max flow mufflers.
Keep forgetting things!
Comp 1.65 Roller Rockers which make lift go to .521 IN .537 EX |
Anybody have a guess?
Oh my bad i guess i shoulda said hydraulic flat tappet.
its not a solid lifter. |
slightly less lift than an LS-3 engine.lesser intake than LS-3,similar heads or maybe better? very free flow headers for a 350.you should be close to the same power plus or minus a little.
| dart iron eagle blocks | pth | Engine | 3 | 05-25-2008 03:31 PM |
| Iron Eagle Platinum or World 220 heads? | Skunk | Engine | 19 | 06-04-2005 10:20 AM |
| Dart Iron Eagle Platinum heads. | Sagacious | Engine | 1 | 04-27-2005 08:24 PM |
| Any experience with Dart Iron Eagle Platinum 200 heads? | Horse_pucky | Engine | 0 | 02-26-2005 09:31 AM |
| What Dart Iron Eagle heads are right for me? | batman09 | Engine | 2 | 09-11-2004 09:25 PM |
