Dart Iron Eagle or Vortech Heads - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-18-2003, 11:03 AM
Jag Daddy's Avatar
1969 Mustang Coupe Project Car
Last journal entry: New Project Mustang, From Jag Daddy to Stang Daddy
Post
Ok Ken:
Thanks for the link my wallet is now very much lighter!!!!!!!
  #17 (permalink)
Old 05-21-2003, 07:45 AM
ztoy's Avatar
speed freak
Post
bull-
did you ever find Mike Adams' website?
  #18 (permalink)
Old 05-12-2013, 11:44 AM
Head Bolts
Ya know....I've got Iron Eagles on my 383 that I built.......and one of the head bolts broke after a number of years (#16)......and #2 on the other side stripped.
I was looking at how thick those heads were, and comparing the stock head bolts to that........and it is CLOSE. I mean they are BARELY long enough to grab.....so I'm thinking.....are there longer/special head bolts for the bottom row of the Iron Eagles?????
PS. All this bull**** about a post being too old is just that.....BS.....Google was kind enough to lead me here, so that's good enough for me........A lot of us are working on older vehicles......and besides....Information NEVER GROWS OLD.........fwiwz
  #19 (permalink)
Old 05-12-2013, 01:06 PM
Sorry....it was #3 that stripped..............z
  #20 (permalink)
Old 05-12-2013, 01:58 PM
Proud LOSER
Welcome back 2003
  #21 (permalink)
Old 05-12-2013, 08:14 PM
Originally Posted by bygddy View Post
Welcome back 2003
Got anything constructive to add on my question..........or is it moot cause they're not making Iron Eagle heads anymore, and there's only one left.....the one I'm working on?????????????
z
  #22 (permalink)
Old 05-12-2013, 08:15 PM
Tapped through the head into the block.....hopefully the HeliCoil will hold........it was a long and winding road fwiw...........z
  #23 (permalink)
Old 05-12-2013, 08:38 PM
vinniekq2's Avatar
you can buy any length bolt you want in any grade.
  #24 (permalink)
Old 05-13-2013, 07:58 AM
OH.......I forgot.....it seems like a long time ago cause you were only 10 years old then.......sorry........z
  #25 (permalink)
Old 05-13-2013, 03:15 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The minimum amount of thread engagement should be >/= 1-1/2 times the bolt diameter. In the case of a SBC block, the bolt should extend all the way through the deck in most cases.
  #26 (permalink)
Old 05-13-2013, 06:01 PM
Thank you for clearing that up!!
I miked the thickness of the bolt boss......the bottom one(s) and it's 1.15 inches.
The bolts effective length from the base to where usable thread ends is 1.5 inches.
Leaving .35 of thread engagement in the block.
1.5 x 7/16 is .656 inches........so there definitely is a problem............
Here's some pictures of the bolt that stripped.....seems like it either broke, or was corroded away??
z
  #27 (permalink)
Old 05-13-2013, 06:04 PM
Remind me to tell you guys the long and winding road of trying to fix this with the engine still in the truck w/heads attached.........z
  #28 (permalink)
Old 05-13-2013, 09:09 PM
vinniekq2's Avatar
why not tell us about the power output of your 383 with those heads?
ets? or other track times that may apply
  #29 (permalink)
Old 05-14-2013, 07:25 AM
hey Vinnie ,I don't consider this highjacking a 10 year old thread just have a question for you .what size carb are you runnining on your stroker and what flavor.installed a 421 ci small block yesterday in my 55 and am currently running my 800 series avs off my 406.i know that it is on the small size for this engine but I had it,anyway the engine is a 421 4.155 bore x 3.875 stroke eagle 6" h-beam rods .the heads are 64cc dart iron eagle 215's with the 22cc dished pistons the comp.is close to 10-1 depending on which calculator used.whats your opinion on size requirement for the carb.oh ya the cam is a xr 286 r turbo 400 tranny with 411's out back thanx for any info.
  #30 (permalink)
Old 05-14-2013, 07:52 AM
vinniekq2's Avatar
my carb
I use a 950 CFM Holley "HP" series.It was cheaper to buy it from the carb shop pre built with proper PVs etc,than to buy it stock and tune it. When I put the carb on it worked very well with just a one size jet change.
For your engine I would say use the 850/950 (your choice,same price)depending on what you want.
From off idle,with a standard, 2.87 first gear ratio,3.50 rear gear,if I go past 1/2 throttle the tires break loose. In second gear around 3,000 RPM,if I stomp the throttle,the tires break loose. If Im at 60 mph in 5th gear (.82:1) if I stomp the throttle to the floor,the car acellerates with out hesitation or bog.
You are using more gear and an automatic so you decide,,,invest in tire stocks
