Dart Pro 1 heads arrived.
All,
Some of you had ask for information the quality of the Pro 1's I bought off of ebay from Yoders. Everything looks very good and I must say it is the best deal I have found in a while. The only thing that is an issue is that there is some casing flash that will have to be ground off for pushrod clearance. Any Dart heads will be this way I am sure. Chris |
Alright. One step closer to getting the S-10 back on the road.
Chris do mind me asking what the total cost was with shipping for those heads? |
It was $990 to my door step. He charges quiet a bit for shipping because he insures them for the actual value and packs them in foam so there is little chance they get hurt.
I got the bottom end back together today, so yes it is getting closer. Just need to get gaskets and stuff on the way now. Chris |
sounds like it could be running in a week.
K |
The guy who does the heads assembles them and does the valve job in his machine shop. Why on earth would I have them surfaced? Are you saying that they are not flat when you get them from Dart? Why would the valve stems have nicks? Chris |
If I am missing something..........this is my first set of aftermarket heads. You all make it sound like they are junk out of the box. Chris |
I've seen some pretty out of wack stuff that was brand new. I think he meant just to make sure everything was on the up and up, thats all.
Turbo.
I dont think anyones trying to bust your happiness, but rather just have you check everything carefully. You know what they say about checking others work. I think it sounds like a heck of a deal to me and Id be interested in seeing the Ebay listing they were on. Do they look like pretty thick decks on em? Can you order them with the size springs you need? Let me know some info on em. Tnx and good luck with em. HG |
Hemmie,
You can get whatever springs you want, but the heads set up with roller springs are a bit more expensive. The heads I got are #110 on the seat. The guy I got them from recommends them for .525 lift, but he said that is just to be on the safe side and they will handle .550 without issues. Like I said, I will check them over before installing them. Here is a link to the heads he is selling, but he has raised the price $25 since I ordered mine. http://cgi.ebay.com/ebaymotors/ws/eB...category=33617 Chris Edit: I just got an email back from another guy who bought the heads from Yoder. He said he had no problems and they made 550HP on a 390ish cid small block and ran them this whole season on a drag car without issue. Last edited by TurboS10; 12-23-2004 at 06:43 AM. |
Tom, chris-
I think clarification is needed here. I bought my iron eagles the same way chris did and just bolted them right on. I found the machine work to be way above and beyond what I expected. Here's the difference. Tom, the problems you've had are probably people who buy the "fully assembled" heads from dart or other warehouses, am I wrong? The difference is, the people who chris and I bought our heads from independent machine shops (much like yours, tom) who sell these heads on ebay for a reduced rate, because they buy pallets of bare casting heads and then do all the machine work in-house. The 200cc runner, fully assembled angle plug, 2.05 heads like I got are something like just shy of 1000 dollars in summit. I got them for 700. (maybe its 900 in summit, dunno). They guy who did my heads put in manley valves, threw in a set of com cams guide plates and actually (get this) UNSHROWDED MY EXHAUST VALVES!!!! Can you believe it?! Some of these guys really know what it means to be cool with your customers and go the extra step for a quality product. As soon as I saw the work I was so confident I just tossed them right on the motor, and I was right, everything was in order. K |
This is from an earlier post of mine:
The worst aftermarket heads i have seen were a set af Canfield sbc heads. The chambers were 3ccs oversize, the heads were warped .013", and the valves seated so badly light shined into the chamber was visible in the ports. Shortly after those heads I worked on a pair of bbc race heads. These heads were each warped over .014". I have also fixed Dart, AFR, World Products, Brodix, and Ford Motorsports heads. The defects i found were: guides too tight, valve guides not concentric to the seats, valve seats too wide, too narrow, and damaged by chipped cutter blades, seats contacting the valve face too far off the inside or outside, broken keepers, lubricant not present on valve stems, and more. My point is that ALL of these problems somehow got past quality control checks and made it into consumer hands. The thing is this: Any of these heads would probably made decent power in spite of the problems because of the fact they are horsepower producing heads. A rough idle caused by leaky valve wouldn't be that noticable with a radical cam. But eventually a valve would stick or eventually burn or a head gasket would leak. I have seen each of these happen on heads that were bolted on. One head in particular was a bbc Dart head. The source where the head was bought from was advised that the valve seats didn't look right. The buyer was told to use them anyway. After little use on the drag strip, a valve head broke off from flexing as it tried to seat on an off-center seat. All I am saying is that if you spend $1500-$2000 or more on a set of heads, it would be wise to have them checked out by a good machinist. We do that for our customers (while they watch) and they are more than happy to see that we found a problem before it cost them a lot more money in the long run. After your previous experience, I'm sure you would rather check things our first............ tom |
Killer,
I think you make a good point. The heads I have were deburred around chambers and the valves appear to be unshrouded. I think that it is actually where the cutter for the big valves(2.08) got against the chamber, but it is hard for me to tell. The exhaust valves appear the same way. Tom, you also make a good point. Could I check the valve sets and angles using lapping compound? Seems like it should show any valves that are not seating properly. Gasoline in the chamber always shows if one is leaking as well. I can check the deck easy enough with a straight edge I figure. About the guides being too tight, I have heard of this before. Might sound dumb, but is it just a matter of feel to see if they are too tight? Chris Last edited by TurboS10; 12-23-2004 at 08:10 AM. |
I can see how the heads have a good chance of being messed up when some dufus in the dart factory just throws them together. But if they're coming from a machine shop, I think its a different story. They know that its not dart's butt on the line, its theirs. I am absolutely certain that my machine shop checked and did the job right.
K |
| Recent Hotrodders' Lounge posts with photos |
