dart pro 1 porous head problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-31-2008, 09:22 AM
zephyrc's Avatar
i have pro 1 heads on my sbc and whilst checking them over prior to putting them back on i noticed that there is a hole in one of the inlet ports,i can see the side of the head stud ..will the stud seal the hole or do they need a repair,, if so how can they be repaired.. these were taken of my motor 2 weeks ago and the hole did not seem to affect it
Old 09-01-2008, 07:25 AM
Shouldn't affect it, It is common when really porting runners to put a sleeve in the hole if ya break thru but usually not needed the stud fills the hole.
Old 09-01-2008, 05:07 PM
Last journal entry: PICTURE TEST
hole
Are you talking about the bottom of the rocker arm stud??? Or are you talking about the stud that attaches the head to the block??
If it's the hole where the stud bolts the head to the block it will need repaired.
If it's the bottom of the rocker arm stud it will just need a little sealant on the threads.
Keith
Old 09-02-2008, 10:55 AM
zephyrc's Avatar
it is where the head stud goes thru the head.. it looks like the casting is porous in that position
Old 09-02-2008, 12:00 PM
head
It need fixed.
I will ream the hole and install thinwall brass tubing.
keith
Is it possible to stroke a 400 more than it already is? stonedchihuahua Hotrodding Basics 18 11-10-2012 08:27 AM
please help..... annoying warm start problem 67cuda Engine 21 03-28-2003 05:44 AM
Vacum Problem 73 dart Lewissr Hotrodders' Lounge 0 11-15-2002 02:13 PM
Fuel / Carb problem DoubleVision Engine 5 10-28-2002 05:18 PM
Head install problem on '93 Z28 Venom93 Engine 7 06-24-2002 09:35 PM
