Dart Pro 1 Valve Spring Pockets - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-18-2005, 02:42 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
While setting up my heads, I don't have room under the springs to insert a hardened shim to make the correct installed height, leaving the aluminum head in contact with the spring. I can't imagine this is good for the heads' spring seat. Is it in fact O.K. to install them 'naked' or should I have them machined for clearance to put some sort of protection under these springs?
How serious is it to install the springs maybe .010 - .020 short of the recommended height as long as I don't run into coil bind or rocker interference?
Old 02-18-2005, 03:06 PM
johnsongrass1's Avatar
Race it, Don't rice it!
You need to get the right installed height. This affect's closed pressure and you don't want the valves bouncing off their seats. It can pop the heads off pretty easily.
Old 02-18-2005, 03:46 PM
4 Jaw Chuck's Avatar
Do not install the springs without hardened shims, it won't last long.
— Han Solo
68NovaSS's Avatar
Moderator
Wiki Edits: 9
I understand that John, if necessary I will have them machined then. I'm not sure that installing them .010 short would be a problem, if anything I'm thinking that would provide more seat pressure. I would never consider installing them taller than recommended. My concern is for the ones that are right on as they are, wear of the aluminum under the steel spring during normal operation. It seems to me the springs would eat into the aluminum in no time at all.
Old 02-18-2005, 08:41 PM
I guess I didn't read well enough. You saying the springs measure .010 smaller than spec, right. I mean .010 less distance between the seat and retianer. I would go with smaller before bigger but the aluminum won't last long under the strain. The shims act as load spreaders. You didn't say what lift but you might get away with a shorter spring and shim from there.
Is it possible to stroke a 400 more than it already is? stonedchihuahua Hotrodding Basics 18 11-10-2012 09:27 AM
Fabricating intake manifold. gemini86 Engine 25 10-02-2009 02:10 PM
What do you all think of Dart Pro 1 heads? TurboS10 Engine 30 12-05-2004 08:26 AM
dart pro 1 215cc head question Jared Engine 15 06-21-2004 02:09 PM
Residual Pressure Valve?? Dave E Shank Suspension - Brakes - Steering 1 12-27-2002 08:12 PM
