Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - dart pro-1's v/s afr 210's
Old 06-20-2004, 02:51 AM
idle.wild's Avatar
idle.wild idle.wild is offline
Hey, if you want a flow comparisson of cylinder heads go to chevy high performance magazine online, go into tech articles and check out the cylinder head flow comparisson. The afr's out flow all other heads, the test was with the 180, 190, and 210 heads right out of the box, those heads are cast only with the cnc'd heads being 185, 195 and 215 cc heads! Good luck in making your choice.
