Dart pro1 LT1 Heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-20-2010, 08:58 PM
Dart pro1 LT1 Heads
So I needed to change the plugs in my S10 and am going to hold of on my 1st gen SB build for now. So I tested the compression on my current motor. It made about 185 to 188 psi cranking PSI. I'm looking to buy the Dart Pro1 lt1 heads to make more power. The cam is a 233/239 569/577 112 lsa. My current heads are a set of port matched LT1 heads with 2.02 1.6 valves non cnc home port match job. Anybody have a set of dart pro1 heads and is this a good investment for more HP?
Current Dyno NA 325WHP 370WT @ 32 total timing 12.9 Air to fuel
pushing a the350 and ford 9"
Lt-1 cjajz Engine 13 11-27-2008 11:41 PM
Trying to get a answer on springs on dart heads? tiresmoke55 Engine 5 09-09-2006 09:55 AM
What do you all think of Dart Pro 1 heads? TurboS10 Engine 30 12-05-2004 08:26 AM
LT1 heads? tonylsg Engine 8 12-19-2002 09:30 AM
Vortec heads or 1971 487x LT1 heads? speedfrk3 Engine 2 10-07-2002 05:12 PM
