DART SHP Block Lifters - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-28-2013, 02:37 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Guys,
I'm getting ready to buy my new Dart SHP 400 block for our sprint car. My question is, this block requires a +.300 taller lifter and just wanted to know why? Is it because the lifter bores are taller?
Thanks
Old 02-28-2013, 09:51 PM
Landshark928's Avatar
FrankenPorsche
Yes. Not to mention if you have a small base circle cam the lifter will sit slightly lower in the bore.
The Following User Says Thank You to Landshark928 For This Useful Post:
lhmurphy (02-28-2013)
Old 03-01-2013, 12:39 AM
1Gary's Avatar
Last journal entry: 383 dyno sym
With our 565 and the 632 we went through a period of sizing issues on the 565 of the lifter bores.MAKE VERY SURE YOU CHECK THE LIFTER BORE CLEARANCES!!!
Old 03-01-2013, 04:42 PM
X2
Iits amazing how many guys buy lifters and just dump them into the bores with out checking the clearance.
Most .841 roller lifters are under size for a .844 bore.
I don't let any block out of my shop with out fitting lifters to the bores.
Dart SHP heads prostcelica Engine 32 08-03-2012 07:38 AM
Dart Shp Sbc 407 Build Help! kertwood Engine 21 12-12-2010 11:46 AM
DART SBF Blocks...SHP V's Sportsman Peter James Engine 2 05-23-2010 12:51 AM
questions about the dart shp block boredandglued Engine 7 12-26-2009 12:41 PM
Dart SHP Short Block Camaro2 Engine 2 11-13-2009 07:04 AM
