They're iron heads, and heavy castings but nothing great without a lot of porting.
I really don't see any appeal for them unless you're required to use them by racing rules. Since you were looking at patriot I assume you want aluminum offshore heads- there are plenty of options available for that. Also with that cam id get a 195-210cc port not a tiny 180cc port. |
check out the 195cc trick flow heads Fast as cast, they are as cast off of cnc ported versions..
Trick Flow® Super 23® 195 Cylinder Heads for Small Block Chevrolet - trickflow.com here is the flow sheet as well.. http://static.trickflow.com/global/i...195%2064cc.pdf and here is my choice for your build the 215 cc http://www.trickflow.com/partdetail....6&autoview=sku and flow sheet.. http://static.trickflow.com/global/i...215%2067cc.pdf and dyno example http://static.trickflow.com/global/i...up23%20215.pdf Last edited by 2wld4u; 07-31-2012 at 12:09 PM. |
The Dart SHP heads I was looking at are aluminum. They have a dual valve sping for use with hydraulic roller cam. I'd post the link on the heads but I'm writing this on my phone. Ill attach the link later when I'm on my computer.
I bought some skip white procomp 210cc for mine! Look really good! I will get shot for this now.........
Here is the link to the heads I am looking at. Being that its going to be a street car isnt a 200cc head to big?? I told Comp what I was doing and thats the cam they recomended
Hey CNC block: Do you like the SHP heads?? Dart 127122 - Dart SHP Special High Performance Cylinder Heads - Overview - SummitRacing.com |
9/12 issue of car craft has a low buck aluminum head shootout. The dart heads have 200cc intakes everything else has 180, if your going to port them all of these heads are promising.
If you have heads that flow 250 plus cfm on the intake side with a 75-80% exhaust flow,for normally aspirated engines,,,,I would go with the smallest cc intake runner that gives the flow numbers I want.This keeps the intake velocity higher on a smaller engine.
on a mild 350 I would consider modified vortecs first.any aluminum head that offers CnC machined,flow tested aluminums next,for a race car,go with specialty heads and custom porting. |
Btw excessive velocity is just as bad as inadequate velocity if not worse. |
I wont be turning the motor past 6500 Tops!!. Probably put a 6000 pill in my msd just to be safe. This will aslo be a street car. Ive read you really dont want to use anything above a 195cc intake runner on the street. Also seen many people say 180 runner is perfect for 350 street motor. I talked to 2 people at AFR one said use the 180's for sure. The other said Because of the weight of my car (2500#'s) he go 195's. Being that im a cheap a** I considered getting a cheaper set of heads(still want decend quality) and port and polish them.
I would like to make 450hp but still have a reasonable amount of tourqe. Any head suggestions would be appreciated. I can get a set of AFR streets to my door for 1715.00 USD. If I could get a set to my door for $1200 and port and polish and achieve that 450hp goal I think thats the way I would go. Im in Canada btw |
stock 292 angle plug heads can make 450 HP with a decent camshaft.My 67 Camaro used GM cast iron heads,solid cam,850 holley,ran high 11s @ 114,car weighed 3600 ish with me in it.
The afr heads can make more power with less cam,you do the math on cost and drive ability. |
| Dart Shp Sbc 407 Build Help! | kertwood | Engine | 21 | 12-12-2010 11:46 AM |
| DART SBF Blocks...SHP V's Sportsman | Peter James | Engine | 2 | 05-23-2010 12:51 AM |
| questions about the dart shp block | boredandglued | Engine | 7 | 12-26-2009 12:41 PM |
| Dart SHP Short Block | Camaro2 | Engine | 2 | 11-13-2009 07:04 AM |
| Dart intake? Brodix or Dart Heads? | Slowass72 | Engine | 3 | 01-20-2004 04:52 PM |
