Dart SS 165 Intake Runners with XE268 cam - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-24-2009, 05:35 PM
Hey, Anyone using the Dart 165ss 1.94/1.5 heads with the
Comp cam XE268 cam in a chevy 355 ??
Please reply,,Thanks
Old 02-25-2009, 08:34 PM
I just installed an xe268, but im running stock GM 1.94s. whats on your mind?
Old 02-25-2009, 08:51 PM
Sounds like a good combo as long as you've got at least 9:1, preferable a tick higher.
I ran this cam before swapping to a solid. It was on a 327 with 462's (1.94's) and 9.5:1. Ran strong 2,000 and up.
Old 02-26-2009, 07:04 PM
Hey, thanks for the replys. I have looked at several builds and
have asked many ?'s about different setups and I am pretty sure
that this is the right build for me. I want as much power as I can
get from this 350 for my 91 S10 Blazer. A freind of mine has this
setup, but with vortec's and a 800 Edelbrock carb. He was making
410 hp and 430 tq. on his engine. If I can make 360 hp and 400 tq.
I will be very happy!!!! I already have the dart ss 165's with 1.94/
1.5 valves, A weiand action plus (idle- 6000) A 770 street avenger,
Block bored .030, and decked. KB120 flat-tops giving me 9.5 compression with heads shaved to 70cc combustion chambers, And the heads are
port polished and gasket matched, with manley street master straight
stem intake and race flow undercut exhaust valves. I got all new comp cam
springs to match cam XE268 rpm 1600-5800. 477/480lift. And I will be
getting an upgrade on the stall. I have a 350 trans. and a 700r4,, I
also have a 342 eaton postive rear-end.
Does this look good for 360hp and 400 tq. Anymore comment?
please reply? Thanks
Old 02-26-2009, 07:17 PM
you will be happy with this engine! you combination of parts will work very well together.
Old 02-26-2009, 08:12 PM
since that is going in a blazer with a 3.42 gear (if you haven't purchased the parts already) I would look at the XE 262 cam. You'll still lay down 360 or more and defenitely hit your torque figure with room to spare.
roller cam selection for my monte ss redbandit98 Engine 37 06-21-2008 11:39 AM
dart ss heads slater83 Engine 5 10-30-2005 09:12 PM
Which Intake do you suggest to be used with Voodoo Cam for SBC??? Houman SS '70 Engine 19 04-27-2005 05:29 PM
cam and intake questions RedRocket Engine 2 11-11-2002 11:41 PM
HELP cam, intake and carb selection? sniper4570 Engine 5 01-15-2002 09:16 PM
